cossie boost
Old Jan 15, 2009 | 03:52 PM
sam182's Avatar
sam182
Default cossie boost
hi what is the most boost that you can run through a standard intercooler, running green injectors any info would be appreciated thanks
Old Jan 15, 2009 | 05:30 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
2wd? 4x4?
you can run as much as you want....the question is what charge temp will you see, and YOU need to measure it, and determin when its dangerously high.
imo they struggle at stage 3.
Old Jan 15, 2009 | 05:33 PM
oldford's Avatar
oldford
The maximum boost is dictated by the chip and/or map-sensor.
So which map-sensor are you using and what kind of chip?
Old Jan 15, 2009 | 06:05 PM
I agree with jtech, the more boost the more heat is created, which is waht we don't want, and would agree nothing above about 320/330 would I run one at.
The cooler can physically take the pressure no problem any that you can throw at it, but that's not the issue.
Old Jan 15, 2009 | 06:11 PM
sam182's Avatar
sam182
hi i think it has a level 4 ecu chipped to 300bhp on a 3 door sierra, i want to make the engine bay look more standard so want to remove the big intercooler and replace with the standard item i dint know what a safe psi of boost would be with the standard intercooler, would it be able to run 20psi and also if you lower the boost on the actuator does the fueling need adjusting or is that all governed by the boost psi through the ecu itself so would not need attension, or how do you wire high and low boost in through the amal valve so it runs low boost until the boost is adjusted on the actuator, thanks
Old Jan 16, 2009 | 06:49 AM
oldford's Avatar
oldford
If you change the intercooler you need to get the car checked. It might affect the fueling a bit too much.
A simple method to have high and low boost is a on/off switch in one of the 2 wires going to the amal valve. You can test the effect by simply disconnecting the electric wires to the amal valve and test-drive the car.
Old Jan 16, 2009 | 07:02 AM
I'd fit a 4wd cooler, will not look out of place and still be fine at 300.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
