Escos tb onto sapph
Does anyone know if a small turbo escos tb/housing will fit straight onto a std 2wd sapph elbow plenum etc.
Not bothered about different TPS, as can just do a reset/align tps, want it for the iscv function.
Thanks
Thanks
It will bolt on - but uses 8mm bolts as standard, as opposed to the 6mm for a 2wd/4x4 throttle body, so you'll have to make up some small sleeves to centralise it.
It also has a larger internal diameter, so some port matching work will be needed - somewhere around 4-5mm on the radius.
DavidK
Sep 27, 2015 02:55 PM
