sierra disc?
Old Feb 28, 2009 | 01:26 PM
crazydan's Avatar
crazydan
Default sierra disc?
i have xr4x4 calipers and cariers waiting to go on my 1.8 cvh (non abs)
question wot disc's can i use? or will i be able to use xr4x4 disc on it?
any help will be great thanks
Dan
Old Feb 28, 2009 | 01:38 PM
mick's Avatar
mick
tbh you are better off with 2.0 brakes... theyare are the same as the xr4x4 but with the correct offset for your hubs............. 4x4 and 2wd drive are different, you may be able to adjust the offset with "spacers" or altering the hub or carrier but i'm not sure.........
Old Feb 28, 2009 | 02:09 PM
1.8cvh and 2.0 litre are both the same at 240mm with a height of 58mm.
You need 2.8i xr4i discs from 82-85, these have a height of 58mm, the xr4x4 discs have a height of 53mm.
Old Feb 28, 2009 | 02:23 PM
mick's Avatar
mick
twinky 2.0 with abs are 260mm............ not sure of the height .
mind you i'm putting granny 278's but i have the complete front suspension and hubs....
Old Mar 22, 2009 | 03:53 PM
crazydan's Avatar
crazydan
so do i use 2.0 disc then?
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
nico12
Dec 31, 2015 04:42 PM
IainRS1700T
Sep 25, 2015 06:44 AM
155lee
Sep 23, 2015 01:27 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
