3dr or 5oo head
Old Mar 16, 2009 | 06:38 PM
jason 3dr's Avatar
jason 3dr
Default 3dr or 5oo head
mine has 3 holes for the thermostat housing and additional casting for a turbo damper, could this be a 500 item or is this just a later one
Old Mar 18, 2009 | 09:41 PM
costina's Avatar
costina
Live long and prosper!!
you can tell bey the water jacket on the exhaust side large one is early 2wd three holes is a late 2wd
If your head has a hole in the inlet face where the gasket goes about 5mm dia then its possible its a 500 head as these where for dowels and i think theres 2 holes
Out of all the 2wd heads the best to have imo is a late 2wd with the 3 hole water jacket
2wd early (not 3 dr) they have 2 thermo bolts
2wd late(note the area under the exhaust manifold is solid for better heat transfer)
Hope this helps a bit
Paul
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
martynhomer01
Oct 1, 2015 12:05 AM
DAZZER
Sep 30, 2015 08:43 PM
