Focus ST brakes on a 1.6 Focus
Hey i was wondering if anyone would know the answer to this.
I've recently purchased a focus st rear axle with st rear callipers disc and pad assembly. I'm looking to fit this to a mk2 focus 1.6 ti-vct which has drum brakes, im basically wondering what else im going to need other than brake flexi pipes and a handbrake cable. i believe that there are abs sensors on these particular brakes, do i need to connect the abs sensors up or can i run them without the abs? I have also heard from people that i may possibly need to upgrade from the 1.6 servo and master cylinder to the st one, is this going to be the case or is it possible that i will be able to run on the original items?
thanks in advance.
thanks in advance.
03-11-2015 04:08 PM
