Saph Cosworth 2wd Diff fluid & gearbox fluid ???
HELP!!!
been told to buy 2.55 litres of "ATF" for the gearbox
1 litre of 90W for the diff
went to motor factors & they were unsure on what to give me for the gearbox
& gave me Comma Gear Oil, Limited Slip LS80W-90 GL5 for the diff...... not sure if this is right
confused now
Ta, Paul
confused now
Ta, Paul
the gearbox takes atf, automatic transmission fluid, if they dont know what that is then they are seriously retarded!
80w90 should be alright for the diff, i use 75w90 semi synthetic for my diff
hope this helps
hope this helps
Ford did originally put ATF in the boxes, but gear oil is better, but you will have a fight on your hands when it's cold though with gear oil!!
As said 75W90 LSD oil for the diff, on no account use NON LSD oil in the diff, make sure it is LSD oil.
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
