throttle position sensor voltage
Old Mar 13, 2009 | 05:43 PM
col93saphcos's Avatar
col93saphcos
Default throttle position sensor voltage
hi,just wondering if 0.2v at idle position is to low,i see from other threads etc should be 0.28 etc,did all my sensors cars running sweet but was wondering about tps setting is it to low on overrun?maybe make no differance,cars a 4x4 saph cossie,just used on road,thanks again col93saphcos
Old Mar 13, 2009 | 07:04 PM
oldford's Avatar
oldford
0.2v is spot on. 0.28v is very close to the limit where the software can learn the idle position. The maximum is 0.3v, above that the ecu will not switch to idling and will not use the overrun function.
Old Mar 14, 2009 | 02:19 AM
col93saphcos
brilliant thankyou very much,col93saphcos
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
