Rotar arm removal
Old Feb 27, 2009 | 03:52 PM
Rs Cosworth 1's Avatar
Rs Cosworth 1
RS for life
Default Rotar arm removal
Hi there the 2wd saff rotar arm will not pull off is it fixed another way or possibly stuck on if so how do i get it off?
Thanks in advance
Old Feb 27, 2009 | 04:17 PM
It should just pull off mate.
Old Feb 27, 2009 | 04:57 PM
Rs Cosworth 1
RS for life
Thats what i thought but it won't budge and is worn out pretty bad TBH and the Diss cap is oxidised so need them doing ASAP but don't wanna break anything,
Thanks glenny
Old Feb 27, 2009 | 05:25 PM
As it is knackered just break it off, put the new one on with a little grease/coppaslip between arm and shaft, they can get extremely stuck on.
When you put new arm on, just check for "ford wiggle", that is play in the slot so the arm moves/rotates slightly on the shaft, if it does, just put a bit of paper over the lip of the shaft and press arm on this will take out any slack.
The cap when you say oxidised if you are just referring to the terminals inside the cap they do this anyway, ie look burnt and pitted, not a reason to change.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Orion_Gav
Sep 29, 2015 04:50 PM
