Series 1 RST Turbo advice
Old 14-03-2009, 06:38 PM
Glynburton
Glynburton's Avatar
Default Series 1 RST Turbo advice
I have recently bought this series 1
Its running a turbo technics stage 2 hybrid 360' turbo but has awful lag, when it does come in it's awesome but as im not intending to turn it into a pod warrior would i benefit from putting a standard T2 back on it?
The next question is will i have to alter the other mods?
Its had Stage 3 head, piper performance cam shaft
- 31 actuator and apparantly a power engineering blueprint conversion although i havent seen any evidence of this...
Thanks in advance
Old 14-03-2009, 08:54 PM
Alvyn
Alvyn's Avatar
[quote=Glynburton;4009926]I have recently bought this series 1
have you had it set up? the lag you may be feeling could be altered by fitting a vernier pulley! and you mean T3 not as what you mentioned as they were fitted on Fiestas m8!
Old 14-03-2009, 11:37 PM
Glynburton
Glynburton's Avatar
Your right , i meant a T3 hybrid.
In the process of finding somewhere to get it set up now, was thinking about changing the turbo first though....i may just see what happens after i get it set up.....The turbo doesnt kick in until quite high in the rev range though, i really want it to come in lower down, hopefully a simple tune may cure it.
Matt Baxter
16-09-2015 08:30 PM
Billy_RS
15
05-09-2015 12:04 PM
A.t.p
15-08-2015 11:37 AM
RsS2daz
14-08-2015 05:26 AM
dlwarrior
05-08-2015 10:19 AM
Quick Reply: Series 1 RST Turbo advice
