drive shaft problem
Old Mar 1, 2009 | 05:45 PM
mark1_123's Avatar
mark1_123
Default drive shaft problem
hi there can anyone out there shine some light on my horrible situation?
i have a mk 5 xr3i convertable cosworth , it has had a rs turbo conversion done (not by me) a couple of weeks ago my wishbones gave way and the driveshaft poped out of the passanger / gearbox side and it is completely distroyed in the knucle i have replaced wishbones not a problem normal escort ones ,the problem i have is i carnt find a driveshaft that will fit they are too short the one that came out had a shim on it behind the hub as that seems too of been to short as well but it was ok untill the wishbones went ,my car has rs 2000 running gear and escort cosworth front hubs to bring the wheels out to meet the kit and a diesil gearbox can anyone please tell me what driveshaft will fit ?
thanks
mark.
Old Mar 3, 2009 | 05:08 PM
JonathanJ's Avatar
JonathanJ
This is going to be difficult , as you have a real mis match of components there , best thing to do is measure the shafts overall length and no of splines with there diameter , and then I will have a look and see if anything I have around comes anywhere close . I would also look at the inner joint and make sure it was running somewhere close to the centre of the plunge available , just in case it was on the outer limits .
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
cossie2
Aug 27, 2015 09:57 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
