ECU advise needed
Old Mar 16, 2004 | 09:58 PM
Default ECU advise needed
ok bear with me. I had a 1.4 CVH PTE engine in my car which runs with same fuelling system as Zetec (SEFI) but I replaced it with a 1.6 CVH EFI from an XR3i which runs on EFI fuelling. Now my car wouldnt run with the XR3i ECU due to it needing an EDIS4 module which my car doesnt have, but does run with a 1.6 Zetec ECU. The car doesnt run 100% but does run ok, I think the fuelling is out due to zetec being a 1.6 dohc 16v whereas the cvh is only sohc 8v. Now what I wanna know is can the Zetec ECU be reproggrammed to work right or do I need to rewire the whole loom and put the original ECU back in?
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Bailes1992
Aug 16, 2015 07:14 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
col93saphcos
Aug 7, 2015 03:21 PM
