Can you check map sensors?
Old Mar 16, 2004 | 11:32 AM
Default Can you check map sensors?
As in the title. Is there a way to check this sensor or is it a case of trying a new one and see.
Graham.
Old Mar 16, 2004 | 12:53 PM
HI,
Graham, quick resistance test without going in to volts checks etc,
pin 30 and 11, at ecu plug,300/600.ohms and pin 30/15, 3000/6000, kohms,
ok, one easy volts check,pin 30,+11-.ignition on 4.5 to 5.5volts at map sensor
plug ignition on, by the way when removing or replacing ecu plug make sure
ignition is off,
Dave,
Old Mar 16, 2004 | 01:50 PM
Dave,
Thanks for your reply. I will check the measurements as said. The reason i'm also checking the map is because on overun i have been getting a slight kangaroo sensation. This has been happening for some time now. Possibly like other people have put it down to the 4x4 transmission. I will let you know how i get on.
Once again thanks for your valued input.
Graham.
Old Mar 16, 2004 | 03:14 PM
Dave Henshall's Avatar
Dave Henshall
when at low speed in traffic....?
mine used to do that - until i got used to it - it when u accelerate and the force moves your foot back off the trottle - u over compensate and press too hard causing it to lurch then let off and so forth - keep it in 2nd when glugging about to try and reduce it.
Old Mar 16, 2004 | 06:17 PM
davidreader5,
Have checked all measurements. All are ok and within said measurements.Thanks.
What happens if you disconnect lambda sensor while engine is running? The reason being is that i can see bare wires on the three that are attatched to the sensor. I have noticed that there is slight arcing from them.I have only noticed this now that i have removed heat sheild from turbo.Would this effect the running while the engine is idling? I did disconnect the sensor when i noticed it this evening and didn't here/or notice any difference in the running.
Dave Henshall,
I know what you are saying. It just makes you jerk about slightly and it get annoying sometimes.
Graham.
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
