engine loom wiring problems
Old Apr 20, 2004 | 09:53 PM
Default engine loom wiring problems
anyone help please
engine loom looks like it used to have a secs monator on it but i cant quite decide what has been done to the loom
im geussing that a group A coil was fitted so i can just run those back into single wires for the time being.
but what is the orange cable with what looks like a coil plug on it? it is next to the water temp plug.
also any ideas what the long coiled up cable was for? or what i should do with it?
i bloody hate electrics
Old Apr 21, 2004 | 04:28 PM
Tony Ryan's Avatar
Tony Ryan
I hate bloody wiring too ! The small " coil " type plug is likely to be for the Water temp sender on a 4x4 head its located next to the small housing on the back of the head .As mentioned a gpA coil suvives nicely on just 2 wires , stumped as to the coiled up wires , monitor or extra gauges , i think your right .
Old Apr 21, 2004 | 09:27 PM
hi darren,if its a 4x4 eng.loom it should be the water guage temp sender wire,trace it back-normally brown with white trace-hope this helps regards -PJ
Old Apr 24, 2004 | 02:03 PM
cheers for the help guys is now sorted and engine is up and running
orange wire just got the snip as did the amal valve wires as they are now on manual overide
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
