Cutting out on boost
Old Mar 9, 2004 | 04:48 PM
Moonie's Avatar
Moonie
Default Cutting out on boost
Got a S2 Escort turbo with a problem noticable on the motorway when accelerating in 4th or 5th gear. When i put my foot down the boost pressure rises and peaks at 18psi and holds at 16, if i continue to accelerate sometimes the engine will cut out (rev counter drops to zero/ignition cuts). If i release the accelerator then press again it will fire up and continue ith no problems.
Any ideas?
Old Mar 9, 2004 | 05:07 PM
PJay's Avatar
PJay
It's hitting the boost limiter and cutting the ignition, it needs the boost turning down
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
