serious misfire
just in the prosess of running in my cossy
but it as develope a fukking mis fire when i try to move off
in frist it backfires and then it dies but it does not cut out
i have check ecery thing fuel pressure is right up there
as any one ever had this problem
i dont thing its fuel starvation cause fuel pressure gauge is
reading ok when this happened
check your coil and phase sensor in dizzy,see if wires have lost insulation and are shorting out,and air gap 0.2-0.3mm.Also ecu feed on battery,last possibility dodgy relay on management loom-regards PJ.If its 4x4 cos,check and clean out 3xmultiplugs on engine loom above rocker cover,or on esc 2x multi plugs nr coil
thanks for the reply i check all those things
cleaned every loom plugs and it was still the same
so i decide to change the dissy and to my suprise
the bastid is perfict check old dissy pahase senser
could not see any thing wrong gaps was fine
thangs anyway
thangs anyway
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
