2wd cossie stage one boost
Old Mar 17, 2004 | 04:00 PM
Default 2wd cossie stage one boost
hello,could someone tell me what bar boost i should be running with a stage one chip.at the moment if i accelerate quite hard in 3rd gear[it happens in other gears as well]with the revs low as the revs rise and the boost tries to come in the car backfires and pops and doesnt accelerate,it pops and spluters for a bit and then clears and the boost cuts in,could this be too much boost?i think its set at about 1.5 bar.
thanx.
Old Mar 17, 2004 | 04:05 PM
PJay's Avatar
PJay
1.5 bar is 22 psi which is far to high for a stage one car, should be 16-18psi depending on the chip
Old Mar 17, 2004 | 04:32 PM
Dave Henshall's Avatar
Dave Henshall
maximum!
about 1 bar peak(15psi) dropping back to about 14 psi on std injectors.
Old Mar 17, 2004 | 06:01 PM
.:Paul:., cheers mate,i will sort it
Old Mar 17, 2004 | 06:02 PM
Dave Henshall, thanx for your reply.
Old Mar 17, 2004 | 07:25 PM
If it still happens after you have turned boost down, look at your spark plugs, they may need changing. I found that I could accelerate gently all the way with mine, but if I gave it stick it would cough, splutter and pop. Got some NGK 9's, problem gone.
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
RsS2daz
Aug 14, 2015 05:26 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
