non starting cossie
Old Mar 10, 2004 | 01:37 PM
Default non starting cossie
just refitted engine and no spark
ive put a plug in the coil lead and when u switch the ignition on it sparks once
but if u crank it nothing happens
Old Mar 10, 2004 | 02:23 PM
PJay's Avatar
PJay
Check all the sensors are plugged in correctly Plug all the leads/plugs in properly
Old Mar 10, 2004 | 02:32 PM
HI,
THE SPARK BEFORE U CRANK IT OVER IS JUST A PULSE FROM THE IGNITION SYSTEM, AS PAUL SAYS CHECK ALL SENSORS AND ALSO EARTHS ARE ON AND MAKE SURE ECU PLUG WELL ON,
Dave,
Old Mar 12, 2004 | 12:59 AM
Stu @ M Developments's Avatar
PassionFords Creator
Phase sensor is plugged in backwards most likely.
Rotate plug in dizzy 180 degrees and try again.
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Alun Gregory
Sep 6, 2015 09:40 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
