clutch problem on sapphire cosworth
Old Apr 6, 2004 | 11:29 AM
Default clutch problem on sapphire cosworth
Having just had engine rebuilt on Sapphire I fitted a group N clutch, the engine is totally standard. It ran fine for about 2 days then the centre bearing started squeeking very loudly, I removed the box and fitted another bearing which cured the problem for about a week, now it's doing the same, I've been hearing that the bearings supplied with the clutch aren't up to the job for the new group N clutch... any advice? Should I ditch the group N and fit a standard clutch? Thanks
155lee
14
Aug 22, 2015 12:15 PM
cossynut2
Aug 19, 2015 11:29 AM
pegaz
Aug 12, 2015 07:30 AM
yawiejon
Aug 10, 2015 08:12 PM
jdsjojo
Aug 1, 2015 08:50 PM
