Fiesta Turbo Amal Help!
Old 18-03-2004 | 08:36 PM
Default Fiesta Turbo Amal Help!
My friends just got a nice little fiesta turbo - however its running on actuator only pressure.
The amal has two hoses one goes to nothing, the other has a T-piece to the air intake... which goes to where on the turbo/actuator? Can anyone let me know asap - just waiting to boost properly!
Paul
Old 22-03-2004 | 08:49 PM
Mike Gurney's Avatar
Mike Gurney
there should be a t piece in the black pipe that goes from the actuator to the compressor
the long end goes to the amalvalve
what boost does it run
it may have an aftermarket actuator on it
Old 23-03-2004 | 12:53 PM
Cheers for the reply mike.
We worked it out from the web (i sort of knew.. but like to b very sure when its not my car). Its only running std pressure.
Amal seems to do nothing however, so hes bleeding off to 9psi till he gets a new 1
Old 23-03-2004 | 01:02 PM
Mike Gurney
9 psi is a bit too much for a car that has not been chipped
i'd recommned a 165 chip and set it to 12/14 psi
i sell frst chips - PM if you need more info
Matt Baxter
16-09-2015 09:30 PM
gchristophi
31-08-2015 11:36 PM
paceo
27-08-2015 01:45 PM
muffster
11-08-2015 06:39 PM
jdsjojo
01-08-2015 09:50 PM
