s2 erst thrust bearing
Old Apr 22, 2004 | 06:48 PM
Default s2 erst thrust bearing
what an annoying racket this makes? is it hard to do? how much parts and labour am i looking at?
Old Apr 22, 2004 | 06:57 PM
swerv's Avatar
swerv
yes you are right it is a horrible noise!!
about £15 parts and gearbox out , you might as well change the clutch while your there
Old Apr 23, 2004 | 12:47 PM
does that mean the clutch is gone 2? the car has got a paddle clutch.is the thrust bearing part of the clutch?
Old Apr 23, 2004 | 04:45 PM
Moonie's Avatar
Moonie
The bearing sits on the end of the clutch release arm, when you press the clutch the arm moves the bearing towards the clutch pressure plate and releases pressure on the friction plate. If the clutch has a few miles on it then as Serv said it makes sence to change the lot when the box is out. If you dont wanna fork out for a new paddle clutch and it's not showing any signs of wear (slipping etc) then just changing the bearing will get rid of the noise.
Old Apr 23, 2004 | 07:24 PM
220TC's Avatar
220TC
just out of intrest what sort of noise does this make ??? I have a nasty 'whining' noise when getting the biting point in reverse and 1st, once the gears are engaged the noise dissapears.................its also a erst s2 with an ap 4 paddle clutch, anyone ??
Duncan
Old Apr 24, 2004 | 01:13 PM
mine started doing that but it does it in all gears now.urs will probably become like mine in time.the clutch is fine (no slip at all) will change just the bearing.appreciate your help/advice.any further comments welcomed.cheers
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
