running in oil
Old Mar 16, 2004 | 09:34 PM
rossatom2's Avatar
rossatom2
Default running in oil
just about finished my rebuild of my sapp cos engine, what kind of oil do people recomend for the running in, as i read somewhere it should not be synthetic, cheers
Old Mar 16, 2004 | 09:37 PM
Badman38's Avatar
Badman38
use some cheap thick oil to run it in with
Old Mar 17, 2004 | 07:54 AM
swerv's Avatar
swerv
mineral oil
Old Mar 17, 2004 | 10:18 AM
Can some explain why, other than cost.
John
Old Mar 17, 2004 | 10:22 AM
Dave Henshall's Avatar
Dave Henshall
it needs to allow the bores/piston rings to bed in against each other ,if superior quality oil was used, this wouldn not happen because it would keep the friction between them too low. a cheap thin running in oil will allow this thus reliving any stress raisers or high spots . this is why it is important not to overrevv the engine during this time as you may be running metal against metal at some points until it has doen it work
Old Mar 17, 2004 | 11:44 AM
Running in oil is very messy and tiring
Old Mar 17, 2004 | 11:48 AM
Dave Henshall
do dum tis!
mk22door
49
Mar 26, 2022 07:15 AM
Chas
Sep 21, 2015 08:57 PM
StephTell
Sep 2, 2015 06:31 PM
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
