cams
Old Mar 20, 2004 | 12:03 PM
Default cams
what would be the best kind of cams i could have in my saff cossie and where i could get them from . the mods are a viper air filter,
green inj, rs500intercooler,3bar map senor,chipped,bigger turbo,exhaust,
adj boost, runs 20-25psi
Old Mar 20, 2004 | 01:43 PM
CossieEdd's Avatar
CossieEdd
Depends on the rest of the spec - if you post that up you'll get a better response.
If you're running anything up to a 803's & T34 (stage 3) type setup then AFAIK you'd be best sticking with the standard items.
HTH
Edd
Old Mar 20, 2004 | 05:25 PM
i have green injctors,viper air filter,dump valve,chipped,rs500 intercooler,3bar map sensor,adj boost,bigger turbo, runs between 20-25 psi
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
