What Spark Plugs??
Old May 22, 2006 | 12:50 PM
Xindi's Avatar
Xindi
Default What Spark Plugs??
Whats the best set of plugs to use for a 2wd Cossie engine running :-
T34 Turbo
BD14 Cams
803 Injectors
Group A 044 Fuel Pump
L6 ECU
205 Block (can't afford a 200 block )
Forge Motorsport RS 500 Intercooler
Just building the engine up now and wondered what the best would be
Any help from you guru's out there would be great
Old May 22, 2006 | 12:59 PM
bud-weis's Avatar
bud-weis
Football Cwazy
denso iridium
Old May 22, 2006 | 01:00 PM
costina's Avatar
costina
Live long and prosper!!
I use pp8 escort cossie plugs set at 0.6 mm 329 bhp 328 lbft
Same spec as yours but standard cams and 4x4 cooler T35
every conversion i have done for people i use these and never had a problem
Nice to see it when finished
Old May 22, 2006 | 01:01 PM
costina's Avatar
costina
i thought denso's you could only use on coil packs?
Old May 22, 2006 | 02:09 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
You thought wrong mate. can be used without coil packs
Old May 23, 2006 | 03:26 PM
Xindi's Avatar
Xindi
Thanx very much for the help guys
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
