T3 Turbo Conversion - What injectors?
Old Nov 26, 2005 | 06:29 PM
ZSDavey's Avatar
ZSDavey
Default T3 Turbo Conversion - What injectors?
I was thinking of using a T3 turbo after the CVH engine rebuild for my Mk5 Fiesta. Could anyone suggest a matching set of injectors for using a T3 Turbo?
It'll be maped using an Armed Bajoo Chip + His services Live mapping it. I didn't want to max out the boost from the T2 Turbo and the beige injectors!
Will i need to upgrade any other parts (internally)?
Can any of your guys post what your running with the T3 Turbo?
Thanks in advance for any help.
-David
Old Nov 26, 2005 | 06:58 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
depends what power what boost
Old Nov 26, 2005 | 07:18 PM
ZSDavey's Avatar
ZSDavey
Say if i was after about 200bhp?
Old Nov 26, 2005 | 07:26 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
i think beige injectors will b fine for 200 bhp just needs properly set up m8 yhats wt people forget if its live mapted should b spot on,ps there is a set of green top injectors on eaby have a look
capable of easily supplying over 300 bhp in a 2.0 zvh Item number: 8017400539 hope this helps
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
Russ Hill
Aug 31, 2015 06:44 PM
mrknifey
Aug 30, 2015 11:48 AM
