3bar MAP sensor
Old Nov 3, 2005 | 05:07 PM
dmcruley's Avatar
dmcruley
Default 3bar MAP sensor
Hi there... i've got myself a 3bar MAP sensor (don't know if you guys understand what i mean). This should fit my Fiesta Turbo. But the engine is runnig very weird with it.... do i have to change anything else to run with a 3bar map sensor ??? I have the OFAB ecu.
Old Nov 3, 2005 | 06:16 PM
sailorbob's Avatar
sailorbob
The ecu needs to be chipped to recognise the 3 bar map sensor. BTW there is nothing to be gained performance wise by using this map sensor without other modifications.
Old Nov 3, 2005 | 06:22 PM
dmcruley's Avatar
dmcruley
Ok , so a 195bhp chip will work fine ???
Modifications... nothing to worry about got a T25 hybride, Beige Injectors, Stage 2 cilinderhead, Waterinjection, GreddyProfecAboostcontroller, and lots of other stuff
Old Nov 3, 2005 | 06:45 PM
sailorbob's Avatar
sailorbob
I believe '195' chips raise the boost limit to 16psi (the limit of the OFAB standard map sensor) so there would still be problems using a 3 bar sensor.
Old Nov 3, 2005 | 06:48 PM
dmcruley's Avatar
dmcruley
But a 3 bar mapsensor would work till 22 or even 29 psi ????
I'd like to go for about 22 psi
Old Nov 4, 2005 | 08:32 AM
sailorbob's Avatar
sailorbob
If you are after 22psi then you would be better off with a 2.5 bar map sensor because of the higher accuracy compared to the 3 bar sensor. You are also looking at needing a chip thats set up for that. A custom map to get the best out of your set up would be advisable.
Old Nov 4, 2005 | 09:20 AM
dmcruley's Avatar
dmcruley
Ok...sounds good, but where to get one???
And, will the 3bar MAP sensor work with a 195bhp OFAB chip with beige injectors???
Old Nov 4, 2005 | 10:05 AM
sailorbob's Avatar
sailorbob
Try Stu at http://www.motorsport-developments.co.uk/ , user name " Stu @ M Developments " on this board.
Not without causing running problems. The problem is that OFAB compatible map sensors output a voltage in the region of 0 -5 volts regardless of their operating range. i.e. a standard sensor may output say 5v at it's maximum pressure reading whilst a sensor with a greater operating range may output only 3.33v at the same pressure and the ecu will be getting a false idea of what the true boost pressure is.
Old Nov 4, 2005 | 10:32 AM
dmcruley's Avatar
dmcruley
cool... will contact them one of these days, is "MAP SENSOR" the right naming of this product??? or is it called otherwise ??
cheers
Old Nov 4, 2005 | 10:36 AM
sailorbob's Avatar
sailorbob
Yes, map sensor is correct. MAP stands for 'manifold absolute pressure'.
Old Nov 4, 2005 | 10:44 AM
dmcruley's Avatar
dmcruley
ok thnx mate.... by the way... very nice site they have some nice stuff up there..... i think i am going to emigrate to england is much easier to pick some great stuff from there
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
