escort interior light delay relay
Old Nov 22, 2005 | 04:09 PM
Dave Henshall's Avatar
Dave Henshall
Default escort interior light delay relay
having found that this was also staying on all the time months ago and draining teh battery (which at first i thought was the only drain - see flat battery post ) i just removed it and was looking for a replacement one from a breaker/ebay etc...
while i was d1cking about with the alarm module, i thought i'd try it again and double ckecked that it was fooked - it was, but what i've done( which i didnt know u could do was to make a link acrosss where the relay goes in the box (R17) on the terminals shown...
the light will work as per normal car without the delay, BUT to my joy, the toad alarm also gives a 20 second delay off function to the interior light, so, when i disarm, the light comes on for 20 secs, or until i start the car, whichever is sooner everyone is a winner
Old Nov 22, 2005 | 07:51 PM
SafeChav's Avatar
SafeChav
mate sounds like your fuse box is breaking down, very common occurence on mk5's. could be wrong though but those relays dont usually play up?
have you got a part number or picture of it, and also pin the numbers on the pins on the bottom?
Old Nov 22, 2005 | 07:54 PM
Dave Henshall
defo not the fusebox mate, its brand new.
defo the relay though, if u pull it out when its should have timed off, it goes off and stays off when u plug it back in, once u open either front door, it comes on and stay on forever even after the door is shut...
this is the kiddy...(in yellow.)
the blue one is the headlamp waser relay, this is also dead, im thinking doe to a spike of some sort at some time and its fooked the transistors up in them
Old Nov 22, 2005 | 07:55 PM
SafeChav's Avatar
SafeChav
just pulled out the haynes manual (had a mk5 1.4 shitbox a while back ) and i can get u one of these relays if you so wish?
like i said very unusual to play up its the same relay as my mk1 orion has.
Old Nov 22, 2005 | 07:58 PM
SafeChav's Avatar
SafeChav
does the headlamp washer relay even have transistors in it???
i know there is circuitry in the interior light ones, but all the headlamp ones ive come across are usually just SPST relays
Old Nov 22, 2005 | 08:00 PM
Dave Henshall
yep, there are very similar in desgn, BUT a different pinout to stop u even fittin gthem, the headlamp washer one gives a different time off aswell, 4-5 secs IIRC
Old Nov 22, 2005 | 08:08 PM
SafeChav's Avatar
SafeChav
oh really?
can you show me the pin out on the bottom? i should still be able to get u one?
Old Nov 22, 2005 | 08:11 PM
Dave Henshall
not bothered about the interior light one now as it works anyway, the toad alarm had this feature built in, just that it was never apparent beofre due to the timer working in parallael with it.
the headlamp one is R22 above, phisically the same looking pin out, but defo not, the common,, live, switched and ouput are all rotated round
Old Nov 22, 2005 | 08:15 PM
SafeChav's Avatar
SafeChav
yeah i mean if u turn the relay over the pin outs on the relay are labelled with numbers, such as 15, 30 etc
can u take a pic or draw a diagram labelling the pins?
and i should be able to get u one
Old Nov 22, 2005 | 08:16 PM
Dave Henshall
ah right, will do 2morrow m8, that relay is at work, tried to have a look at it with a scope, but couldn't fathom why it wouldnt latch.
Old Nov 23, 2005 | 08:26 AM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
Right mate this buse boxs are very known as fault I mean they get damaged quite easy and they are expencive to replace for a new one so if you dare you can do what I did, open the box completly so you end up with just a cicuit board and with a soldering iron or gun and a good amount of soldering wire reinforce every little one of the spots that you can reach. Then obout you relay what you can do is replace the relay with something like the r18 pin If the worked for me that could work for you as well.
Old Nov 23, 2005 | 08:28 AM
Dave Henshall
it did, see above
Old Nov 23, 2005 | 09:19 AM
cocaina_xr2i
wrench it all
nah mate what I mean is that you have to remove the three plastic covers and stay with the actual cucuit board (the green thing inside the box) then do the soldering and then give it a try.
Old Nov 23, 2005 | 09:59 AM
Dave Henshall
yeh, but ive made link exactly like the R18 link from the bits of the relay,
its now obvious that its not got a relay there, just a link as per any other escort, but i still have the same functionalaity as if it did due to the toad alarm
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
sridgett
15
Aug 3, 2015 07:26 PM
Old ford
Jul 31, 2015 06:50 AM
