Parts i will need for cossy management !!!
cossie management
You,ll need an ECU .L6 or L8 the later is better.
The ECU loom either L6 or L8 depending on ecu but i think they are interchangeable with small mod to TPS wiring.
A dizzy that will fit ur cvh head but with cossie pick up sensor in it or go coil pack conversion (go to M>A>D webshop to find out more on this )
All the cosworth sensors.
AIR temp
Coolant senor
map sensor
amp module
amal valve
cam sensors /phase sensor Dizzy part.
crank sensor
cossie injectors with efi fuel rail of an frst and regulator
id use a cossie fuel pump
My brain says there is more but its early and i cant think ne more ,lol
AIR temp
Coolant senor
map sensor
amp module
amal valve
crank sensor
