Cossie 4x4 front wheel bearings (near side)
0-60 in 17 seconds (eek)
I got a wheel bearing kit (not OE), which contains two things that look like oil seals and two bearings.
Now, the bearings in the kit are "straight", whereas the bearing I have on the outer side (hub side), is tapered.
Are the inner and outer bearings different, or, am I missing something obvious ? Do I need an outer kit as well ?
The bearings I have in the kit have the following markings on them if that helps
TIMKEN
JXC18437CA
Y32008XZ
Thank you
TIMKEN
JXC18437CA
Y32008XZ
Thank you
:UP:
Looked at the new bearings more closely and they look like they are tapered inside, maybe it's just that one bit of the bearing came off with the hub, and the other half is stuck in the spindle
Cheers Radman, that's what I wanted to hear
Someone who knows what he is doing is taking the bearings out and putting new ones in, I only took the spindle off the car
Just wanted to make sure I had the right parts.
Fun part is going to be putting it all back together
We'll know for definite tomorrow
