Ford Orion Problems
Old Nov 18, 2005 | 10:16 PM
blinky's Avatar
blinky
Default Ford Orion Problems
Hi all need some help if you can.
I own a Ford Orion 1.6 CVH (1993 i think(J reg)) 83000 miles. I havent had it long and has been a good running till now. I have a couple problems :
1. Wether the engine is hot or cold i have alot of juddering when i push the throttle, any gear doesn`t matter, i have replaced the spark plugs, HT leads and the coil and that hasn`t sorted the problem. It can get a bit hairy when i am in traffic and the car suddenly jumps forward.
2. The heat coming out of the heater matrix is no way near hot enough. I get into the car in the morning and i have to wait about 10mins before i can see out of the window and even then its still misted. I have flushed the cooling sysytem out and plugged a hose line into the base of the matrix to wash out and debris and blockage, but i still dont have much heat. The base of the matrix is hot and there is a little heat there, but with the winter here now i need more to drive.
If anyone has any ideas what these problems are and how to sort them out i would be really grateful as i and my mates have run out of ideas and i cant afford to let someone rip me off if its something simple.
Cheers all
Old Nov 19, 2005 | 12:11 AM
NUTS RuS's Avatar
NUTS RuS
Are the hoses (well one at least) going into the matrix getting hot when the thermostat opens ? Simple quick pointer to check first.
If so then there is still a blockage, if not then its possibly a thermostat or hose blockage problem.
Juddering - can you explain more - it the engine juddering ie rev's dropping etc or do you mean its actually trying to drive off ?
Oh and welcome to Pf
Old Nov 19, 2005 | 06:53 AM
HORNETS7's Avatar
HORNETS7
hi m8 the juddering to me is either engine or gearbox mounts knackered or its something to do with your clutch !
either ratchet and pawl incorrectly set stretched clutch cable or just the clutch is knackerd !
Dr. Ickxs
Aug 15, 2015 11:34 AM
gingerturbo
Aug 11, 2015 09:44 PM
slammedorion
21
Aug 6, 2015 11:38 AM
orionguy
Aug 6, 2015 07:36 AM
