help needed with engine management
Old Nov 23, 2005 | 03:08 PM
16vzetec's Avatar
16vzetec
Default help needed with engine management
if i tell you what im running and what info i need and see if you can help.
running;
2.0l zetec
90 spec xr3i efi engine management
st170 injectors
bike throttle bodies
problems;
i am concerened that the st170 injectors will be ok on efi management?
also concerened if the bike throttle position sensor swithch will work on the efi management.
does anyone know for sure???????????????????????
spoke to someone about the injectors earlier and they said that they 'should' be ok
JoeyBoyden
Jan 4, 2024 02:36 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Seanyfarrell
Aug 14, 2015 11:37 PM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
