Sapphire Cosworth Mis-Fire
Old Nov 20, 2005 | 03:07 PM
Sticky's Avatar
Sticky
Default Sapphire Cosworth Mis-Fire
Hi there looking for some help.
I have got a 1991 4x4 sapphire and it mis-fires on constant throttle, when reved it runs sweet and it also wont idle.
I have changed the plugs, crank sensor, phase sensor and had a general look around.
This is a strange one as parked car up fine then next time went to start it this happened, any ideas???
Steve
Old Nov 20, 2005 | 07:57 PM
2001ode's Avatar
2001ode
Hi,
May be the TPS.
To be sure, disconnect TPS and run. If engine is OK, TPS is faulty. Remove with throttle case, dismantle carefuly, and clean up resistor track with alcohol very very light.
Claude
Old Nov 21, 2005 | 03:14 PM
Sticky's Avatar
Sticky
Thanks for the help, got it sorted. Found to be map sensor broke.
Steve
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
