2wd cossie rear beam.
Old Nov 28, 2005 | 07:09 AM
Adam Edwards's Avatar
Adam Edwards
Default 2wd cossie rear beam.
My 2wd saff has failed its mot on n/s chassis leg and rear brake pipes.I am going to remove the rear cradle complete with diff as a complete assembly so i can get good access to the legs.Is this the best way of doing it?Is thre anything i should be aware of before starting?It looks pretty straight forward but any advice would be much appreciated.
Old Nov 28, 2005 | 08:01 AM
foreigneRS's Avatar
foreigneRS
Testing the future
it is very straightforward. don't forget to take the brake pipes out of the brackets in the body though, otherwise the axle will hang off the flexibles.
while you're there, i would replace the doughnut bushes at a minimum, and inspect and replace all others as necessary. why not also change the brake flexibles to braided. i would also drain the diff and refill with fresh oil.
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
rog
Aug 30, 2015 05:32 PM
RsS2daz
Aug 14, 2015 05:26 AM
lockie
Jul 31, 2015 10:03 PM
