Sticky Valves
Old Nov 29, 2005 | 10:35 PM
fiesta_rsturbo's Avatar
fiesta_rsturbo
Default Sticky Valves
hi all hoping someone can help,
My mums got a 1996 escort 1.6 ghia saloon
she keeps having trouble with it when starting from cold
Ive changed the maf sensor but this made no difference, she took it to a garage who told her it was a sticky valve.
Just wondering how much of problem is this to replace ??
All help will be appreciated
Thanks
Old Nov 30, 2005 | 08:25 AM
bell's Avatar
bell
try changing the oil to fully synthetic. when i first got my fiesta, i put normal oil in it and it ended up with the same problem when cold. quick oil change and it was cured.
Old Nov 30, 2005 | 10:25 AM
fiesta_rsturbo
Default sticky valves
Thanks mate will try this at the weekend
Old Nov 30, 2005 | 10:59 AM
DazC's Avatar
DazC
IIRC the Zetec oil grade is something like 5w30 and it's thin for this reason (sticking valves).
Old Dec 3, 2005 | 10:37 PM
perdu55's Avatar
perdu55
dazc is right the correct oil is 5W30 also use a flush before you change the oil it can often help cure the problem , also dont rule out the ignition system check your plugs leads and coil pack they might be getting damp overnight i always check the compressions when the plugs are out on zetecs with starting/running problems
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
