removing abs from s2 rs
Old Nov 16, 2005 | 09:23 PM
stevenebm's Avatar
stevenebm
post whore
Default removing abs from s2 rs
how hard is it to remove abs from rs turbo.doing an under body resto and took the load valves off at the back and thot i could do away with them alltogether and the rest of it
Old Nov 17, 2005 | 06:36 PM
HORNETS7's Avatar
HORNETS7
piece of piss m8
get rid of the abs modules and all pipe work connected to them!
u will have 2 solid brake pipes going from master cylinder to each abs pump then 2 plastic return pipes from abs pumps to resivior!and 2 solid pipes running from the abs modules to 2 t pieces in each inner wing!
once u have ditched all these u need to have 2 new brake pipes made up !u need to connect both pipes to the master cylinder and the other ends to 1 of the t pieces in the inner wings ie one to the left t piece on inner wing the other to the right t piece on inner wing!
next u will either have to blog up the 2 rubber return pipes to resivoir or to do it proper get a resivoir of a non abs escort xr3I
bleed all 4 wheels up and job done !
Old Nov 17, 2005 | 08:32 PM
stevenebm's Avatar
stevenebm
post whore
hmm sounds no bad.mite give it a go mate
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
