hydraulic handbrake
Old Dec 2, 2005 | 03:40 PM
mbeblue70's Avatar
mbeblue70
Default hydraulic handbrake
can any one tell me how to plumb in a hydraulic handbrake system. i am running seperate calipers for the handbrake
Old Dec 2, 2005 | 05:38 PM
ian sibbert's Avatar
ian sibbert
Does that help...you would need to substitute the feed from the rear brake master cylinder with a resevoir but that shows the idea...
Regards
Ian
Old Dec 3, 2005 | 06:52 AM
HORNETS7's Avatar
HORNETS7
i'm sure hydrolic handbrake are not allowed for mot purposes !?
correct me if i'm wrong?
Old Dec 3, 2005 | 08:17 AM
mbeblue70's Avatar
mbeblue70
cheers for the picture sibster. can i run the handbrake with its own reservoir feed fitted to the master cylinder instead of using the rear brake reservoir. the reason i ask is i have twin calipers on the rear. 1 for rear brakes and 1 for handbrake. as for the mot my local tester has said if it meets the requirements when tested then it should be fine
Old Dec 3, 2005 | 09:36 AM
ian sibbert
Yes matey you can fit a reservoir to the hyd cylinder itself.....it will be a stand alone system with your independent rear calipers....Hornets7 is right though it should fail an MOT, as to comply you should have a mechanical form of park brake as well....some MOT testers turn a blind eye to this fact and it may pass but make sure you leave the car in gear if you park it on a hill cos with the hyd system alone it will, after the brakes have cooled allow the car to creep off down the hill....
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
