What boost should i run?
Old Nov 15, 2005 | 11:50 AM
robertlondon's Avatar
robertlondon
Default What boost should i run?
i have a 4x4 saph with a t34, stage 1 chip, exhaust. running 15psi. i'm goin to put on rs500 intercooler, -31 actuator, breather system alng with some cosmetics i.e. samco's what boost do you guy's recomend i run on that setup?
Old Nov 15, 2005 | 12:29 PM
Alvyn's Avatar
Alvyn
15psi would be about the most on a stage 1 set up!
bit of a waste of a t34 to use on stage1 IMO
Old Nov 15, 2005 | 05:13 PM
Dave Henshall's Avatar
Dave Henshall
as above, u can maybe get a peak of about 20psi at 3.5K then back off to 14 psi at the top - assuming that the chip will fuel it like that, my setup does, but the l8 ecu on a saph doesnt do closed loop boost control,,, so 14-15 psi held will have to do..
Old Nov 15, 2005 | 06:26 PM
robertlondon
it was a stage 3 but the guy took off greens chip intercooler sold it seperate and just left the turboand i bought it like that. so i should leave the boost till i get a stage 3 chip and greens? i have a l6 ecu from 2wd in it.
Old Nov 15, 2005 | 09:17 PM
twitchyrear's Avatar
twitchyrear
stage3 chip&greens, depending on chip 21-24psi
JK12
33
Apr 26, 2021 12:09 PM
dombanks
Sep 21, 2015 08:38 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
