need to turn up fuel mixture on ERST
no mate. I had it on my s2. SCC performance told me to do it and result was amazing. They said they do it to every car they fit the kit too. I'm not gonna lie to you though. You do notice bit more fuel consumption - but then maybe thats because you put your foot down more to get bigger flames lol
I didnt notice it straight away. Had bout week then it started working but then i was told the older the plug the better the flame.
ok mate. i got confused too.
I take it you got the turbo?????
basically next to the top of the inlet pipe is your tps (little black box with a connector on bottom). It has 2 screws (one either side). Loosen these, there is no need to remove them. Once you have loosened them I'm pretty sure you turn away from you so towards your windscreen. It will pivot on those 2 screws.
Cant remember what way you turn but you will not do any damage either way. its trial and error. Im pretty sure you put it back not forward so that it clicks or doesnt click. Once you have done that just tighten screws again.
Also make sure engine is warm because flames aren't very likely on cold engine and also doesn't flame very well on idle. You will notice late at nite when you drop a gear. I had flames climbing up my spoiler. could see them through rear window, LOL
So if it dummy guide but didnt know if you would know what bits were, no offence
i will see if i can find my email from scc. hope this helps
can i just hold you all in mid conversation....?
throttle position sensor adjusting on a Fiesta Turbo???
throttle position sensor CLICKING on a Fiesta Turbo????
I think your talking about an Escort Turbo?
however please correct me if im wrong
lol u lot! i dont have a fiesta no more! I DO have a ESCORT! im just stuck with the name stusfesta! and gotta change my sig.............
ANYWAY! ive got the odd flame, only seems to do it when i accelerate and change up the box. fekin huge! the throttle position sensor didnt click and it was already towards the bulkhead so i put it half way between, it didnt click though??
have you got a new spark plug in there. It took mine a couple of weeks to start working properly.
I found it was best when you were in top end of third gear then let of the accelerator
no it will still only go on one way. maybe it is broke. I have a spare one though. I will check it see how much they turn
Will only go on one way because the connection inside is kind of like a rainbow shape with a flat bottom.
JK12
33
26-04-2021 01:09 PM
