lambda sensor
Old Nov 8, 2005 | 03:41 PM
boost mad's Avatar
boost mad
Default lambda sensor
need a wide band lambda sensor for my gauge type thing. is the 4x4 cossie 1 wideband. if not where to get one from?
ifankoo
Old Nov 10, 2005 | 05:57 PM
boost mad's Avatar
boost mad
Old Nov 11, 2005 | 06:54 AM
the original's Avatar
the original
4x4 sensor not wideband.
does your gauge manufacturer recommend one?
Old Nov 11, 2005 | 09:08 PM
boost mad's Avatar
boost mad
i canthonestly remember, its a racetec 19led jobby if that helps
Old Nov 13, 2005 | 11:02 PM
richm's Avatar
richm
if the gauge isn't expressly designed for a wideband sensor (wideband doesn't normally display as LED's...) it will be no good.
Wideband sensors require a complex driver/control interface to work, it's a lot more than a simple display!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
