Best welder for seam welding shell *amateur*
Im looking for a welder, I want to learn the skills , what do I need to start welding seams on my car, what Amps, gas, arc, MIG TIB BIG PIG???? Anybody recommend a make and model that will do most things car wise on a budget, (not thousands£££ ).
What do you use???
What do you use???
wrench it all
at last something im good at for you mate if you are using gas less weld try setting the speed of the wire so it not too fast or too slow also check that the lengh of the wire is no more that 1/2 of an inch, remember if you are doind panel welding in your car you be better of doing little spots and giving it a chance to cool down so the metal won't flex. see I have got two of them 1 gasless and with gas I got them at b&q (cuz of the price) and the work really well they were about £300 for the two of them.
Well done for trying man any help try my E-mail we may be able to use msn messanger
ive bought a sealey 180 amp mig realy powerfull mig with 0.8 wire or 0.6 will weld upto 7mm thick steel easily and u get a free compressor too all delivered in 2 days !
oh also its best to get a fan assisted welder for continous use as fanless ones loose there power when hot !!!
http://cgi.ebay.co.uk/SEALEY-SUPERMI...QQcmdZViewItem
bargain !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
OK, Ive decided on MIG welding for starters using 0.6 wire, whats the minimum and max AMPS i will need on a shell and panels, 30 AMP low enough- 130 AMP max high enough?
I have my eye on a CLARKE 135TE Turbo, mostly due to the price for the spec, SEALEY equipment looks expensive unless you find a deal you really want/need?
YEAH I KNOW THE BUDGET CAN BE A PAIN SOMETIMES BUT IVE LEARNT THIS BEFORE , BUY THE BEST AMPAGE ONE THAT U CAN AFFORD ! OR SAVE UP FOR A GOOD ONE AS LIKE ME IVE HAD 3 WELDERS BEFORE I DECIDED TO GET MYSELF A GOOD ONE
WHAT THE HELL!
WHAT THE HELL!
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
