zetec turbo smoking when not boosting
Old 17-11-2005 | 12:15 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default zetec turbo smoking when not boosting
my zetec is smoking cant realy tell if it just with weather or what but i has also started letting big pops out the exhaust ,when u go on boost it seems ok no smoke .
any ides
will get this on the road yet
Old 17-11-2005 | 08:36 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
mines doing the same thing atm, having a new turbo soon so hopefully its that
breathers ok? oil return big enough?
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
made my own breathers could this b the prob
Old 17-11-2005 | 08:47 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
IF I DISCONECT ALL BREATHERS WOULD THAT WORK ONLY HAPPENS NOW AND AGAIN SEEMS TO B MORE IN REVERSE JUST WENT FIRST PROPER RUN TODAY SEEMS OK BUT BOOST COMES IN ABOUT 3.5K STRONG AT 4 ANY IDEAS WHY SO LATE???????????????
THANKS AGAIN M8
Old 17-11-2005 | 08:48 PM
Chrissy_bwoy
depends if they r blocked or not
Old 17-11-2005 | 08:53 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
NOT BLOCKED M8 FRESH HOSE 25MM DIA FOR BREATHERS AND 50MM DIA FOR OIL RETURN BUT I DID MAKE MY OWN CATCH TANK OH OH
THIS MIGHT B THE LAST I MAKE LOL,SHOULD IT MATTER HOW ITS MADE
Old 17-11-2005 | 08:56 PM
Chrissy_bwoy
2"????
im sure they is a specific oil breather design dunno what it is tho
Old 18-11-2005 | 06:57 PM
tonyturbo's Avatar
tonyturbo
round about 15mm is ok for an oil return.
Old 18-11-2005 | 07:13 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
hey tony how u doing
so if 15mm is ok 50 mm should b ok should it not what happened with ure breather what were ure simptoms
Old 18-11-2005 | 08:27 PM
patrick's Avatar
patrick
Chrissy bwoy... Read quite a few of your posts now, you seem to know your stuff.!
Wonder if you could help me.?
Do you know.? or know were.? i can find out the bends required for tubes in zetec turbo build.?
Many thanks
robnock
21
13-05-2019 05:29 PM
robnock
22-08-2015 10:51 AM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: zetec turbo smoking when not boosting
