XR2i TURBO CONVERSION
Old Nov 9, 2005 | 08:46 PM
RSKICKER's Avatar
RSKICKER
Default XR2i TURBO CONVERSION
Can anyone tell me what i need to do for a conversion, as i have been told that i only need to change my pistons and ECU as well as the map sensor.
Also a bit of modification to the wiring loom may be needed.
Is this true or have i been fed a load of bull!!?
Old Nov 9, 2005 | 10:51 PM
antony215's Avatar
antony215
Escort Rs Turbo
xr2i bottom end ain't the same as a fiesta turbo bottom end the xr2i bottom end has no oil feed for the turbo so you would need a turbo bottom end it's not as easy as you've been told bit more to it than that
Old Nov 10, 2005 | 04:12 PM
Moonie's Avatar
Moonie
You will also need a turbo
Old Nov 10, 2005 | 05:26 PM
stusfesta's Avatar
stusfesta
.....and exhaust!
Old Nov 10, 2005 | 07:36 PM
RSKICKER's Avatar
RSKICKER
Cheers stu, how easy to dump in a EFI turbo motor, say out of a festa RS.
How complicated the wiring be on that mate.
Old Nov 10, 2005 | 10:02 PM
stusfesta's Avatar
stusfesta
its really easy. i put everything out of my FRST into an xr2i shell its pretty simple and if you think you mite forget where wires and pipes go then write notes or take pics as you go along
Old Nov 12, 2005 | 12:29 PM
RSKICKER's Avatar
RSKICKER
cheers stu, is the fuel tank the same and wot is a swirl pot.
Also where is the map sensor on my car?
Old Nov 12, 2005 | 02:01 PM
stusfesta's Avatar
stusfesta
the fuel tank is the same but the pump isnt, it will need changing. Map sensor is at the back of the engine bay, should be a big black plug going into it i think. hav to ask someone else about swirl pot im not entirely sure wot they do
Old Nov 12, 2005 | 08:06 PM
RSKICKER's Avatar
RSKICKER
Cheers stu, ive never been quite sure wot a swirlpot is either.
Ive just been offered a 1800 zetec motor out of a 1800 2i, suppose to be 238 brake proven, will it fit and how hard you reckon mate?
Old Nov 12, 2005 | 08:33 PM
RSKICKER's Avatar
RSKICKER
Cheers stu, just been offered a 1800 zetec turbo out of an 2i 1800.
suppose to be 238 bhp will it fit and how easy mate?
Old Nov 13, 2005 | 09:59 AM
stusfesta's Avatar
stusfesta
yea it will be easyer than turbo, just get all the loom aswell and it will be pretty straight forward i should think mate
Old Nov 27, 2005 | 11:02 AM
RSKICKER's Avatar
RSKICKER
Another question for you stu. Can i use the head off my 2i on a turbo block along with my inlet manifold.
Old Nov 30, 2005 | 12:37 PM
opposite lock's Avatar
opposite lock
Default Re: XR2i TURBO CONVERSION
A swirl pot is a unit which sits in the petrol tank on the bottom . the fuel feed comes out of the pipe on the tank which comes from the swirl pot. Think of it as a holder of fuel which always has a constant supply to the pump . Its to prevent a surge although u can still get a surge if ur unlucky . Im no pro but thats what it does. Use an accumalator aswell , think this prevents any air in the fuel line .
Old Dec 11, 2005 | 05:32 PM
RSKICKER's Avatar
RSKICKER
will the head of my 2i be ok to use on a turbo block
Old Dec 12, 2005 | 01:40 AM
opposite lock
yes but you must use the turbo camshaft .
Old Dec 12, 2005 | 10:09 AM
JesseT's Avatar
JesseT
I've found the efi camshaft quite wonderful for turbo actually.
Old Dec 12, 2005 | 10:20 AM
opposite lock
Quite wonderfull ??? What u mean by that ? i hope its an EFI turbo camshaft and not one from a N/a engine ???????
Old Dec 12, 2005 | 12:07 PM
JesseT's Avatar
JesseT
N/A cvh efi cam, as in a 91-92 mk5 1.6i Escort.
Old Dec 12, 2005 | 08:09 PM
RSKICKER's Avatar
RSKICKER
The cam is the same all the way down to a 1300
Old Dec 12, 2005 | 08:56 PM
JesseT's Avatar
JesseT
No, not the efi.
And even othervise, Ford (and other spare part providers) does sell the same cam as a spare from 1300 to RSTs, but it doesn't mean that the cars came from factory with identical cams.
Old Dec 16, 2005 | 12:34 PM
andre_k's Avatar
andre_k
238 bhp....
please tell me its a zetec turbo, not naturally aspirated...
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
