xr2i running prob
Old Nov 25, 2005 | 03:42 PM
Toe Knee's Avatar
Toe Knee
Default xr2i running prob
Firstly its a 1.6 8v
Right had an ongoing prob and its getting on my tits now!!!
Basically can get the car started, but it'll idle for a few seconds then die.
The only way i can get it to start then idle and not stall is disconnect the vacuum hose going to the map sensor.
IF i gently press the throttle the rev's rise but you can hear its not quite revving right, almost like a slight miss-fire but the does rev all the same.
But if i blip the throttle its doesnt like it and sounds like its backfireing and tries to stall unless u back off, usually around 1-2k revs more than anything.
Ive tried 2 different map sensors and a differnet ECU and another EIDIS sensor and various outher sensors like the TPS but its still doing it
Also took the inlet off and found the head to manifold gasket was fooked around the temp sensor so hoped it was just an air leak but its still doin it now its back together!!
Works better than it did before when i was trying to sort it a mont or so ago but as above still isnt the same, found out the garage i took it 2 had unplugged the water temp sensor and left it off which is why i couldnt even start it before
Any other idea apreciated
Old Nov 25, 2005 | 08:52 PM
SafeChav's Avatar
SafeChav
i dont know a fantastic amount about these yet im currently researching EFI for a conversion, slowly learning.
I'd say give the Flywheel position sensor a check, and a clean they get quite dirty and i believe this affects the operation, that sensor being a key one to starting the car, without it the igniton wont spark at the right time.
Check it by unplugging it and connecting a volt meter, SET TO AC VOLTS, across the terminals and turn the car over, you should get a voltage. The voltage depends on speed. If thats ok try the coil pack aswell.
Although if it runs its unlikely to be that.
Try the crank sensor first
ill see if i can find out anymore
Old Nov 25, 2005 | 10:21 PM
Toe Knee's Avatar
Toe Knee
Cheers mate, thinking about its 1 of the only sensors i havnt changed or tried another of, but i did take it out and clean it so deff isnt dirty, could be fooked thou so worth a try!
Other than that cant think for the life of me what it could be Deff gotta be electical thou so.
Old Nov 26, 2005 | 04:09 AM
SafeChav's Avatar
SafeChav
its always the last thing you try...
You could try testing it although from the problem you are having it sounds like the fault wont be detectable on cranking.
Hopefully you can get a spare one cheap?
Ive got loads of EFI spares been stripping all the cars at the local scrappy ready for the conversion. Never have too many spares I'd say it was electrical too cant be a lot else? If the problem persists i wouldnt overlook the injectors either?
let me know how you get on
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
gcfcos
88
Sep 15, 2015 03:48 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
