fiesta rs turbo on boost problem
Old Nov 6, 2005 | 05:38 PM
pollocks's Avatar
pollocks
Default fiesta rs turbo on boost problem
right ave picked my new frst up today bit of a bargain but on boost theres kinda like a hesitation/missfire
if i feed the boost in real slow it takes off quite well no hoping around but if i just floor it, it is kinda like hitting the limiter but its at any revs and stays like this until i let off i'm not getting to full boost by doing this though and also if its got less load on the engine like downhill its more likely to work normally
i don't have a boost gauge to check the boost but it should be here very soon is it possible that its a boost limiter the black flaps off the bottom of the ecu could it have had a chip taken out and the boost not turned down ?? does this seem familar to anyone thats done this
or could it be a missfire if so whats best to replace the leads with i have put new ngk r plugs in just now and its still the same
forgot to mention sometimes i can boot it and its fine and properly flies am well happy when its like this so its intermitent
i have wiggled all the wires n hoses around the map sensor and nothign happened there didn't change the way it was idleing
i removed the dump valve just to check that it wasn't a split diapharm and tbh i prefare chatter neway but it does seem to be very loud
i don't know how loud it should be for 7 psi but this chatter rivals my mates stage 3 cossie
sorry ave been a bit vague but am trying to get it all down here if u wonder nething just ask as i'll try to add more info from your questions
Old Nov 6, 2005 | 06:06 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
at a guess i would say the boost is set to high with no chip in the ecu
Hope this helps
Old Nov 6, 2005 | 06:10 PM
pollocks's Avatar
pollocks
i hope so and i hope my nomad boost gauge it got off ebay turns up soon too as the cheque cleared early last week
btw forgot to mention it has a bleed valve on it but its wound all the way open could this still be raising the boost upp ??
should a i remove it i don't like bleed vlaves to start wi lol but just wondering if it will make a diffrence if its fully open :s
Old Nov 6, 2005 | 06:43 PM
HORNETS7's Avatar
HORNETS7
does the revs drop off?
if so its over boosting !
if u wind the bleed valve in it should reduce the boost sufficient enough until u get your boost guage
then ditch the bleed valve nothing but trouble!
Old Nov 6, 2005 | 06:47 PM
pollocks's Avatar
pollocks
so ins boost down and outs boost up :S
just checking as i got told out anti clockwise is down :S
Old Nov 8, 2005 | 07:59 PM
pollocks's Avatar
pollocks
it was the boost limiter and all is well again
carlo
24
Oct 5, 2015 08:20 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
knight19770
Aug 4, 2015 12:36 PM
Escortdriver1
Jul 31, 2015 02:36 PM
