zetec on R1 carbs
zetec on R1 carbs
does anyone no where i can get an adapter plate to fit gsxr1000 throttle bodies onto a 1800 zetec? also has anyone done this sort of modification before? sold my cosworth recently and looking for a way to breath more power into my escort gti without going down the expensive route of turbochaging. cheers for any help guys.
sorry mate i meant carbs, im planning to run a 4 carb set up of either a gsxr1000 or an yami R1. the jenvy throttle bodies are cool but way 2 expensive as im saving for a house, i can get a set of R1 carbs for about 80 notes n with dynojet kits in them should see plenty power increase the main problem is getting an adaptor plate, the R1 carbs stand upright on the bike so it will have to be like an open ended inlet manifold i.e with a 90 degree bend from the head. need to find some numbers for some decent engineering firms in manchester who can manufacture this can any 1 help? the other main problem is taking a vac but i was thinking of using the ports the carbs have for balancing. fuel wise i was thinking of using either a pressure relief or a pressure regulator to control the fuel pressure. finally the tiny problem of getting the engine management to function correctly minus the injectors +various other sensors. any help any of u guys could give me would be top banana. cheers.
Dave bogg , near scarborough
He does these conversions and im sure he will sell you just the bits you need ,
D.G Bogg & Son (Dave Bogg),
The Garage East Lutton,
Malton,
North Yorkshire.
Tel: 01944 738234
Malton,
North Yorkshire.
Tel: 01944 738234
spoke to the above guy today - what a really helpful bloke going up next week an talk over some specs of manifolds + carb jets etc. the only questions i have now are
1 - will the engine management (zetec) system produce a spark? as far as i can work out ill only be using the coil pack and possibly the crank sensor? all the other sensors as far as i can c i will not need, can the ecu be re-mapped for this set up or will i hve to go for an aftermarket setup which has been suggested to me? all i need is to produce a spark now surly?
2- will i need to fit some sort of pressure regulator/relief valve into the fuel supply? i dont want to flood the carbs.
Dave will be the best man to advise on spark arangements , as far as i know you will need a after market system , as spark advance etc is controlled by the ecu along with a lot of other things and it might get confused ,
pressure regulator u can get from tweeks , a remote FSE one will do the job , low pressure and with a vacume advance
I think lumination or DTA would be your best bet bud ,
But dave bog would still be your best bet , as he;s dont a few of them befor .
ordered a dta e48 ignition only system( bogg recomended) pick it up on monday
if any1 lives in the north west area i would highly recomend urban racing in warrington top advice and top blokes well impressed.
1 more thing does anyone no if u can get a de-cat pipe for a 1.8 zetec? had a look at loads companys but no one lists 1 or does anyone no an exhaust manufactures in the north west?
cheers guys
cheers guys
cheers mate, u dont have a contact number for them by anychance?
bugger ill no for next time mate, got it for a pretty resonable price anyway cheaper than anyone else. the advice the guy give me (called steve) was cool talked me through all the options and add ons i need, said they would give me a basic map to run the car and would set it up for me afterwards. i will deal with them for stuff i need in the future anyway. do u deal with them?
Originally Posted by stesrst
does anyone no if the megasquirt system will run this?
thanks for the tip jesseT but i have bought the dta system now. the biggest plus with the dta is there is someone local to me who can map the management and set and balance the carbs for me. thing is since i sold my cossie i have not got another car so its gonna have to be quite reliable with having a tuner who can sort both its a big plus.
sending the carbs for the manifold to be made this week and should have the management by tommorrow so its coming together slowly.
has anyone fitted a dta ecu to the original zetec loom? just wondering if anyone has something like a conversion diagram i.e wiring colours and locations in the multiplug?
also does anyone no if there is any bike guys on here who could sort us out with some sock filters for R1 carbs?
im sure there will be loads of questions an posts on this before its running so cheers for the help an advice guys.
Hears a big bike breakers , they always have loads in
Colin Appleyard Ltd
Wellington Road
Worthway
Keighley
West Yorkshire
BD21 5AJ
Tel: 01535 606311
Colin Appleyard Ltd
Wellington Road
Worthway
Keighley
West Yorkshire
BD21 5AJ
Tel: 01535 606311
look in your local yellow pages aswell mate ,
I just know colin appleyards place cos he's one of the biggest round here
ive had a look mate and tbh theres not much, a mate of mine has an 2001 R1 he gets all his stuff from tweeks, he is running a ramair kit on his which wont go on the car. there is not many places round here for bike stuff. taking the carbs upto boggs prob thursday so if that place in keighley has got anything at the right price ill call in ther on my way past.
bin bugging steve at boggs that much over the last week he prob give me a black eye when i get ther lol. A big up to him by the way hes bin a big help so far.
carbs are away dta management got here this morning
looked at the wiring diagram to convert the plugs from ford to dta
has anyone done this before? i have the 2 wiring diagrams but cant seem to make any sense wire swapping. any help would be top, cheers guys
5 year old thread resurrection?
Awesome.
I'd ask these guys (the fabricators of said manifold):
Awesome.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
