will 4x4 cossy head fit 2wd block
can someone tell me if a 4wd cossy head will fit on a 2wd 205-block, if you change the water pump to 4wd is that all or.......any other problems to fit head.
cheers
cheers
it will fit but there is no lip for the turbo damper so you have to fit an after market type! also a couple of miner changes water temp switch and oil feed need relocating!
ps water pump is on the block NOT the head so you can still use the 2w/d one!
also using a 4x4 head with 2wd pistons will also increase the compression ratio, which isn't good
sorry confusion about water pump.....will the 2wd therm. stat housing fit 4wd head... cause the 4wd one connects to the water pump with 2"ish rubber hose
cheers
cheers
big_Rad
15-09-2017 09:36 AM
lockie
31-07-2015 10:03 PM
