fuel pick up problem maybe...
Old Nov 27, 2006 | 12:06 PM
gigford's Avatar
gigford
Default fuel pick up problem maybe...
I`ll fit a custom 7 gal alloy tank for a capri 2.8i soon.
The fuel pick up pipe dia in the tank is 8mm. As I know the bosch fuel pump input is 15mm.
I`m planning to use a 15-12mm and a 12-8mm reducers to connect them.
I`m going to mount the pump as close as possible to the tank but I was told the pump might struggle to pick up the fuel.
What do you think about this?
(I could return the tank to the manufacturer to enlarge the pick up pipe, but I`d avoid this if possible that way mentioned above.)
muffster
13
Sep 3, 2015 09:40 PM
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
TrevCos
Aug 22, 2015 06:05 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
