handbrake light on S2
Old Dec 12, 2006 | 09:27 PM
Hrsturbo's Avatar
Hrsturbo
Default handbrake light on S2
as above - keeps flickering on and off and stays on for ages till I hit a few bumps in the road.
how can I stop this without removing the bulb lol
Old Dec 12, 2006 | 11:49 PM
SafeChav's Avatar
SafeChav
You can stop it by fixing your brakes.
The fluid level in the reservoir will be low, and thats low either because you have a leak or because your pads are getting dangerously low, either way, thats fairly critical in my opinion and you should give all the brakes a once over, dont just top the fluid up.
Old Dec 13, 2006 | 05:40 PM
Hrsturbo's Avatar
Hrsturbo
I have no sensors on my pads and the fluid is on max lol! sometimes I can stop it by playing with the handbrake
Old Dec 13, 2006 | 05:47 PM
KSA-Cossie's Avatar
KSA-Cossie
Check the wires on the resevoir plug top.
Old Dec 13, 2006 | 06:37 PM
SafeChav's Avatar
SafeChav
It hasnt got anything to do with pad sensors
Check the adjustment of the handrbake and switch if your confident your brakes arent at fault.
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
