bleeding escort brakes
Old Nov 30, 2006 | 12:37 AM
BM's Avatar
BM
Default bleeding escort brakes
Anybody want to tell me the proper way to do it?
Thinking there is air in the system
1995 ford escort
Ive got a 500ml bottle of DOT4 here, is that enough?
Old Dec 1, 2006 | 07:47 PM
djmillsy's Avatar
djmillsy
Fife Radge
the way that i do it is you need two people
one to work the pedal and one to work the nipples
take the cap of the brake fluid res
that start from the futhest a way brake pas back than drive back then drive front then pas front bleeding them one at a time
get the boy in the car to pump the pedal till theres pressure and then get them to hold there foot down and you relase the nipple till fuld leaks out or air then shut adn and pump the peadal you keep doing this till your getting fluid coming out with no air remember to keep the res filled it can take a while but ive never had probs doing this hope tihzs helps you
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
