COSSIE 4X4 AUTOMATIC CHOKE???????
Old Dec 8, 2006 | 09:33 PM
TOPPS's Avatar
TOPPS
Default COSSIE 4X4 AUTOMATIC CHOKE???????
MY MOTOR HAS JUST STARTED BEING DIFFICULT TO START.THE AUTOMATIC CHOKE DOESNT SEEM TO BE WORKING.IT TAKES ABOUT 15 TURNS FOR IT TO BE STABLE ENOUGH TO EVEN TO START TO IDLE ON ITS OWN WITHOUT CUTTING OUT.ONCE THE CAR HAS WARMED UP IT IS FINE.ANY BODY GOT ANY IDEA OF WHAT TO LOOK AT FIRST.ANY HELP WOULD BE MUCH APPRECIATED.
Old Dec 8, 2006 | 09:45 PM
jon@work's Avatar
jon@work
idle speed control valve on the top of the throttle body - remove the 2 bolts and yank like fuck (it won't twist out) - clean it out with WD40 or similar until the internal bit is free to slide (it's probably black with crap)
either that or it just needs setting up properly
Old Dec 14, 2006 | 08:54 PM
TOPPS's Avatar
TOPPS
PROBLEM WAS THAT THE PLUG HAD COME OF THE WATER COOLENT SENSOR.SORTED
cossie330
Oct 7, 2015 08:22 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
