4wd engine with 2wd sump....question
Old Dec 27, 2006 | 09:28 PM
2wd's Avatar
2wd
Default 4wd engine with 2wd sump....question
Hi...so does anybody know if there is some problems with this setup. will evrything fit ??
Some time ago I was told that it was a direct fit, (2wd sump on 4wd engine) I have now been told that there could be a problem with the oil picup pipe is that correct ??
If so how can solve this problem...??? fit a new 2wd oilpump and pick up ...or ???
Please advice
Also about the oil dipstick...as it is I have the 4wd setup there too....and again it's said that it will read wrong when using the 2wd sump..... ???
Old Dec 31, 2006 | 05:57 AM
Alvyn's Avatar
Alvyn
I have used a 4x4 engine in mine but I changed the oil pump and p/up to 2w/d items!
you CAN use the 4x4 pump and p/up but you have to grind away some of the inside of the 2w/d sump as the 4x4 pump/p/u hits it IIRC!
ps think if you use the 4x4 dip stick(one with the plastic end) it shows more than what's actually in the engine again IIRC been a few years seen I done that!
Old Dec 31, 2006 | 09:23 AM
2wd's Avatar
2wd
ok...so I should get my hands on a HP 2wd pump and a 2wd pick up pipe....correct ?? Will I be able to change it if remove the sump...or do I have to do more ???
and what is the difference between the 2wd and the 4wd oil pump and p/up... ?
what i the IIRC ???
about the dipstick..are you using the 2wd one ?? and it cant be much difference on 2wd and 4wd...
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
